2D Window Contents Disappearing With 3D
I'm working on a project I started in AC9 and have imported into 10, along with the Plotmaker file, and I'm running into an odd problem. Whenever I look at something in the 3D window and then try to go back to the 2D window, the entire 2D drawing has disappeared, and I can't figure out how to get it back.
Anyone have any idea what's going on here, and how to fix it?
TIA.
Wendy
2 Replies 2
It sounds like it might be some kind of graphic card issue, especially since it was a problem before as well (same computer?). Other users have suggested downloading and installing the latest graphic card drivers. You might give that a try and see if it resolves any of the problems
Djordje
Wendy,
The same problem was reported by many users of the Australian student version, and they pinpointed it to a penset problem. See
http://archicad-talk.graphisoft.com/viewtopic.php?t=12025
http://archicad-talk.graphisoft.com/viewtopic.php?t=11880
Try changing your penset, or going back to the 2D by using the preset view, not just F2. How to you go to 3D? via F3/F5 or by invoking a view?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
