2nd story issues...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-02-12 10:38 PM
‎2007-02-12
10:38 PM
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-12 10:40 PM
‎2007-02-12
10:40 PM
Also, the stairs only show up on the 1st floor plan even when they are supposed to be story sensitive..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-13 03:11 PM
‎2007-02-13
03:11 PM
Make sure stairs are set to show "One story up".
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-13 04:04 PM
‎2007-02-13
04:04 PM
what version of AC?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-15 05:15 PM
‎2007-02-15
05:15 PM
AC10 on intel mac
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-15 05:23 PM
‎2007-02-15
05:23 PM
Try to set a good high to your needs in Document>Floor Plan Cut Plane...
Patricia Leão
AC21 INT Full
MacOSHighSierra
AC21 INT Full
MacOSHighSierra
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-16 09:02 AM
‎2007-02-16
09:02 AM
This shouldn't be happening, have you checked you have the correct level heights in the story setting?
Have you checked if you have two walls where you see one, and maybe the second is set to automatic?
Try deleting the wall you see on the second floor, what happens then?
It must be something like that happening...
at least, I cannot think of anything else..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-16 03:45 PM
‎2007-02-16
03:45 PM
You are aware that the cut plane height is stored with the saved view. This is critical in that it allows you to have a different cut plane for each different saved view. Cut planes and the associated settings in the walls etc. are complex and I recommend using "symbolic" settings for everything that does not need the added control that cut planes offer. A screen shot of what you want would help with giving you the solution.
