Tom Krowka
A hole in fill
Is there a way I can put a hole in fill, the same way I would make a hole in a slab or a roof?
I have a rectangle within a rectangle, and only want to fill the area between the rectangles.
The typical fill does the whole rectangle without eliminating the center portion. I tried with magic wand, selecting either edge, but no luck there.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
10 Replies 10
Stress Co_
Select the edge of the fill to bring up the pet pallett and select the "subtract" tool.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Tom Krowka
Thanks.
I guess I did not look far enough.
[email protected]
www.walshkrowka.com
You don't even need the pallette. If you highlight the fill just draw another one inside it. Same as a slab or a roof. I have a feeling magic wand doen't work when doing this but don't quote me on that.
Julia
Link
It should work to subtract, but unfortunately it won't work in one single step.
Link.
Tom Krowka
I tried the fill, then highlight and draw another on top......did not work. Maybe I did miss a step as Link implied.
What is the missing step?
[email protected]
www.walshkrowka.com
Ben Odonnell
Tom,
It is important that you have your fill tool selected in the tool box. If you don't, the selected fill will simply be de-selected.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Link
Tom, please take a look at the attached animation to see how it's done.
Link.
Djordje
The fill tool has to be active.
This works on any polygon (fill, roof, slab) - and for the reason above I made it a habit to select the objects by right clicking, and choosing Select and activate tool. Then you draw the hole.
So: in order to make a hole in a polygon, the polygon tool has to be selected and the tool has to be active.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Tom Krowka
Thanks all. Guess I got that one down.
[email protected]
www.walshkrowka.com
