Project data & BIM
AC 17 Building Materials
Erich
I am just starting to create a template for the new AC 17 and am now attempting to wrap my head around the building material attribute. Does any one have a clever idea or best practice for organizing this new attribute?
While it seems to fix a number of things and is quite powerful, it also seems like it could get unwieldy quickly if not well managed.
I am hoping the community (at least the beta testers) might have some good information to be shared.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
38 REPLIES 38
Maybe the Role you are using does not allow you to modify Building Materials (or any attributes for that matter).
You can check and modify Roles in the BIM Server Manager.
If that is that case, you will probably have toleave the TW project and join again for the changes to take effect.
I've started today with cleaning up my template and therefore also the building materials list.
The template from AC16 that I used has a lot of cut fills that are the same material, but just the usage of it is different. For example concrete: there are several concrete cut fills for slabs, walls, beams, columns... I think it is to make a good schedule that also refers to the specifications and conditions.
Now the translation to AC17 makes all these concrete cut fills into seperate building materials. I believe this is not the point behind the building materials? There's just concrete (maybe armed and not-armed) and you use it for beams/walls/columns etc.
Rick Thompson
You have more than one due to priorities, lines weights, line over rides, defaults tool settings etc ... all being slightly different in the migrated file. Maybe things you didn't realize had slight differences. It is really simple to fix. Figure out which one you like the best, and delete/replace the others with that one. However, you might actually need a few that are very similar, but vary slightly as above. I always end up with several concretes, and I only use one. The others are from default tool settings, ones I never use. Pretty quick fix though.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Thanks for response. But in such a case the same restriction would have stopped me from creating new materials or duplicates of existing ones - wouldn't it? and this I can do. Will check tomorrow anyway, hope you are right. Thanks again!
I've started with a new project in AC17.
The new priority based connections are really great for simple connections and details, but it doesn't make sense to me why these PBC keep existing when the materials is cut with SEO.
For example in the picture below:
I've a composite wall with masonry, insulation and plaster.
It connects with a composite slab with concrete / insulation and plaster.
The priority is slab > wall > insulation/plaster. This way the masonry always connects before the insulation and plaster.
In the section the masonry cuts the insulation of the slab because of its priority. After SEO with downward substraction the masonry keeps cutting the insulation....
I could make different building materials for the insulation and plaster of the slab, but then I don't get clean connections (line appears because of 'different material') of the insulation of the wall with the insulation of the slab.
Does someone know a solution for that? Or do I have to split my composite wall into wall AND insulation/plaster so I can give the wall an higher wallbase?
Tx in advance.
You have found an interesting scenario.
I assume that the PBC is executed by ArchiCAD before the SEO. Actually, all PBC connections are internally done as SEOs so it may be that PBC SEOs are performed before normal SEOs.
I would probably try to create a Complex Profile for this Wall in this situation so you will not need to perform the SEO.
Gerald D Lock
I hear and feel your pain Erich (and others)!
I'm CAD manager at a practice that is hoping to move to AC17 'soon' and the building materials issue is looking like quite a task.
I'm taking the approach I took with composite wall creation a few versions back, using a simple 'paper-rock-scissors' approach to establish priorities. The list was borrowed from another AC-talk contributor, but I can't find the original post to give further credit (sorry, but this forum has become an unwieldy, hulking mass of tit-bits and sundry chit-chat)
Essentially wall skin priorities were ranked (lowest to highest):
0 - Finish : Secondary - wet finishes such as paint, plaster, etc
2 - Finish : Primary - dry/panel finishes such as boards, sheet cladding, etc.
4 - Thermal/Air Space - all solid insulation skins plus non-core voids, cavities and air spaces
6 - Membrane - solid membrane skins such as asphalt, rubber, sarna etc.
8 - Substrate/Battens - boards such as ply, particle, MDF, etc. and straps, furring, top hats for fixing
10 - Cavity/Air Space - core-only voids, cavities and air spaces
12 – Secondary Wall Structure - bearing elements such as solid concrete, timber & steel frames, masonry that beams cut through
14 – Primary Wall Structure - bearing elements such as solid concrete, timber & steel frames, masonry that beams do not cut through
16 - High priority bespoke use - use for walls to manually override beam priority '15' and wall priority '14' elements
Beam priority values just used the 'odd number' alternatives to these.
So, my Building Material 'strength' list will likely follow suit, but slightly modified.
The 0-999 strength range provides a HUGE range for each of the above categories (there are 9 above), so I'm thinking I'll assign categories as follows:
0-99 - Secondary (wet) finishes
100-199 - Primary (dry/panel) finishes
200-299 - Thermal/Air Space (finish)
300-399 - Membrane
400-499 - Substrate/Battens
500-599 - Cavity/Air Space (core)
600-699 – Secondary Structure (unit masonry, timber & steel frame partitions)
700-799 – Primary Structure (structural concrete, structural timber & steel frames)
800+ Override values for 'special' skin materials that may be needed, such as to trim wall elements to the correct roof/shell planes
Assigning Cut-fills and Surfaces to each Material is then a simple matter, once the above priority system has been established. As in prior versions, you just need to make sure you have a cut fill defined for each building material you use
Due to the large range of possible values, there is room in this simple list for other intervening priorities. I can't think of any right now, but I'm sure they'll come up.
Any feedback comments on this proposed system would be greatly appreciated as I admit it is very much a work-in-progress with considerable beta-testing (!) to do.
In this regard, I really think Graphisoft could've taken a bit more pro-active responsibility and at least conducted a working group (perhaps one per regional release) as part of beta-testing to establish such a suggested list that could be used 'out of the box', but that's another issue.
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
fuzzytnth3
As this topic is about Building Materials I hope it is ok to ask if anyone can explain why I have a warning triangle displayed next to the Surface pop up
See image below
Using AC25 5005 UKI FULL
James B
If you hover over the warning icon there is an indication that legacy mode is currently on. You can turn this off under Project Preferences > Construction Elements.
When legacy mode is on, then parts of the Building Material settings are not in use (or only partly used) - you can get a better description via the info button next to the legacy checkbox as mentioned above.
James Badcock
Gerald,
I think that the current default Building Material set and their Intersection Priority Numbers do reflect to some degree the Graphisoft guys' idea of a possible working solution.
However, I agree that there could be more work done on this.
But I also think that there will be many variations from one geographical area to the next due to materials and building technologies. For example, here in Hungary there is practically no wooden frame family houses built (except for pre-constructed one you can order from a catalog) so we don't really have to take those BMs into consideration much.
I can only encourage Talkers to share their BM sets once a fairly workable solution is found.
