iggiv
AC 28 Explore mode strange stick key behavior
Team:
I’ve been experiencing some issues with the EXPLORE MODE, which I initially thought was related to a button. I downloaded the new update today (28.2.0), but the issue persists. Therefore, there must be a setting somewhere, but I can’t figure out where it is. When I select the EXPLORE MODE from the menu or toolbar, the model seems to automatically step down and doesn’t stop. I have to press the ESC key to exit the mode and switch to ORBIT mode.
Is anyone else experiencing this issue? Or do you have any ideas on what could be causing it? Any suggestions will be appreciated.
11 Replies 11
iggiv
Team,
I’m vey happy to share that I’ve identified the root cause of the issue. It’s not related to "Archicad", but I’ve install a couple of small utility programs that I find incredibly useful. One of them is “TypeIt4Me,” and the other is “Magnet.” I encountered an issue with one of them, but fortunately, it was resolved with an upgraded to be compatible with macOS 15. However, I believe they still need to be upgraded to the latest version of the operating system. I’m not entirely sure which program is causing the problem, but I’ve temporarily disabled them, and the issue has been resolved. I hope this information helps someone else in the future.
iggiv
Team,
I’m writing to share an unusual experience I’ve been having with my computer. The most frustrating issue has been a delay in response time. It’s not freezing, but it’s definitely noticeable. Initially, I suspected that third-party software was causing the problem, but after following a suggestion to reinstall ODs 15.5, all the issues have been resolved.
I hope this information helps someone else who may be experiencing similar problems. I’m back to using AC 29 without any strange behaviors.
