ā2017-08-23
11:34 AM
ā2023-05-24
07:56 PM
Rubia Torres
ā2017-10-20 07:56 PM
Yes... but didn't quite get what you did EmbarassedI think that this is a good compromise!
What I understood is that you solved by using the finish stair twice, the second one used as "structural" and tread and riser parameters modified. Is this correct?
Thanks.
ā2017-10-21 08:32 AM
sinceV6 wrote:SinceV6,
Yes... but didn't quite get what you did![]()
Thanks.
ā2017-10-21 09:13 AM
ā2017-10-27 11:18 PM
alemanda wrote:OMG. Such a simple and elegant solution!
I used the stair without finishing as structural element, another stair with the finishing only as finishing element.
The structural one is moved 30mm forward and 50cm down in order to be correct.
ā2019-02-27 11:18 AM
ā2022-05-24 11:01 AM
This is the only correct final conclusion. The program is painfully underdeveloped at this point. All ideas on how to deal with it, even if effective, are absurd. If the cladding of the stairs is called a Finish, it should be subject to all operations related to that term.
