2024-02-22 11:56 PM - edited 2024-04-29 12:57 AM
EDIT: The cause of the issue is that DrawShadowsDuringNavigationOGL is bugged. This affects performance even when shadows aren't turned on. It needs to be set to 0 in the Registry Editor under:
Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\Archicad\Archicad 27.0.0\GSModeler\DrawShadowsDuringNavigationOGL
I have been dealing with severe 3d performance problems in Archicad 27 (frame rate drops, stutter, unresponsiveness) that are not present in 26. 3d window is the default Detailed Shading, no shadows. These mostly affect medium sized projects. I have lodged a ticket through Central Innovation (reference number #142104) and have been discussing this issue for months. I am very reliant on using the 3d window for my modelling and it needs to perform properly for me to be able to work in Archicad.
So far the Graphisoft developers have failed to carry out a proper investigation or even attempt to understand what my issue is. They have come back with nonsensical responses that don't address anything I've raised.
The problem is so severe that I have been unable to use Archicad 27 and have had to stick with 26. I have attempted to investigate on my own, provide workarounds, provide videos demonstrating, perform cleans, run FastLogger and suggest avenues of investigation, PLA files. Yet, much of this has been ignored and misunderstood by the developers.
This is clearly an unacceptable state of affairs. I am still waiting for a proper response and to be actually able to use 27. This is on top of the 2d drawing infrastructure being completely broken with scaling. So, both the 2d and 3d are broken - I am trying to help and it hasn't gone anywhere so far.
I am not sure if this is just isolated to Windows and if other users are experiencing similar issues to me? I am also not sure what everyone else's experience is dealing with technical issues but I don't often hear much positive on that front.
2024-06-26 02:29 AM - edited 2024-06-26 02:35 AM
I did try this, as well as messing around with all the hardware acceleration settings, but it didn't seem to do anything for me.
I have heard back from the developers and they confirmed it is a bug that is under further investigation. So we'll have to see how it goes.
2024-09-11 01:50 PM
Hi I unmarked "...Frames pers second" in one file... and it worked, but in another file not. I want just say to GRAPHISOFT, that the problem is spreading and it might mean also that there is an incompatbility with Nvida drivers or Windows 11 that is updating constantly.
2024-10-23 09:40 AM
Something related. I've run into a very annoying exprience during creating a 3d document. Some surfaces were rendered weird and the shadows also. Then I applied the changes in the registry to RenderingAPI and DrawShadowsDuringNavigationOGL what MASz suggested. It solved the problem. See the attached screenshots. Thank you MASz!
2025-01-21 09:44 AM
I did some tests by disabling the "Hardware acceleation" for some apps that were running always on my PC like:
Discord
Chrome
Steam
Tidal
Windows GPU "Hardware Acceleration"
It seems that Archicad runs smoothly without lagging. Usually Archicad started fine but when I was using those apps a response lag appeared.
This has dissapeared and 2d and 3d loads faster and scrolling is normal always.
Can someone try and describe the results?
Greetings to all.
2025-01-21 09:58 AM
Is that disableing hardware acceleration in other programs while using it in AC, or with it disabled globally?
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2025-01-21 10:11 AM - edited 2025-01-21 12:03 PM
Apps like Chrome, Steam,Discord,Tidal have an option in their settings to disable GPU acceleration.
Check whether you have other apps on your own that might have an option to disable it.
Also windows have a GPU acceleration in their graphic's setttings. I also have disabled that.
I don't think there is a global disabling option though.
In any case Archicad feels a lot better all day working.
Even the info tab refreshes faster.
