AC27 Stair 2D symbol idiosyncrasy
AC 27 2D symbol baffingly wtfs when turning tread finish on. Happens on both this stair and some other one with similar settings.
Check the line types used in the 2D view.
Looks like it is using a symbol line rather than solid or dashed.
It could be the line type for the tread, riser, tread accessory, etc.
At 00:08, the Floor Plan symbol becomes very weird. What are all those lines? Is that a display error?
Are you using the default Archicad Tread from the library or is it a custom Tread?
It was that. A funky line type in Tread > 2D Representation > Hidden Parts. Thanks very much.
