AC27 Stair 2D symbol idiosyncrasy
AC 27 2D symbol baffingly wtfs when turning tread finish on. Happens on both this stair and some other one with similar settings.
1 Solution
Check the line types used in the 2D view.
Looks like it is using a symbol line rather than solid or dashed.
It could be the line type for the tread, riser, tread accessory, etc.
Go to post
3 Replies 3
At 00:08, the Floor Plan symbol becomes very weird. What are all those lines? Is that a display error?
Are you using the default Archicad Tread from the library or is it a custom Tread?
It was that. A funky line type in Tread > 2D Representation > Hidden Parts. Thanks very much.
