2025-02-26 07:21 PM - edited 2025-02-26 07:35 PM
AC 27 2D symbol baffingly wtfs when turning tread finish on. Happens on both this stair and some other one with similar settings.
Solved! Go to Solution.
2025-02-27 02:06 AM
Check the line types used in the 2D view.
Looks like it is using a symbol line rather than solid or dashed.
It could be the line type for the tread, riser, tread accessory, etc.
2025-02-27 01:11 AM
At 00:08, the Floor Plan symbol becomes very weird. What are all those lines? Is that a display error?
Are you using the default Archicad Tread from the library or is it a custom Tread?
2025-02-27 02:06 AM
2025-02-27 03:05 AM - edited 2025-02-27 03:06 AM
It was that. A funky line type in Tread > 2D Representation > Hidden Parts. Thanks very much.
