‎2016-05-03 03:25 PM
‎2016-06-24 01:40 AM
‎2016-06-24 02:08 AM
gpowless wrote:yes.
With the direct import & conversion of all Sketchup models into ARCHICAD 20 there is no need for manufacturers to supply objects for ARCHICAD format anymore.
‎2016-10-09 07:53 PM
‎2016-10-10 11:01 AM
‎2016-10-10 11:50 AM
TMA_80 wrote:Looks very nice. I am doing this with lots of roofs on top of a slab at the moment, followed by covering it up with a fill in plan view, because contractors/clients keep getting confused by seeing all the actual gradient connections and such.
I don't have any comment to the 20th version , but here is something that could perfectly fit into the building world and into the productivity "small" features:
https://www.youtube.com/watch?v=_MaXWqMz2P8
( Note that is already present in Revit since...a long time )
‎2016-10-10 02:40 PM
Erwin wrote:You can get there pretty quickly with the mesh to roof goodie using a composite roof, although some cleanup may be required due to the triangulations.
Could also try it with a mesh, but that won't have the different layers like composite have.
‎2016-10-10 03:13 PM
Richard wrote:Good tip, but the gradients generally are pretty easy to model with single plane roofs (CTRL + click edge to get mitred joints between them). I merge these with horizontal roof / slab and it looks fine.Erwin wrote:You can get there pretty quickly with the mesh to roof goodie using a composite roof, although some cleanup may be required due to the triangulations.
‎2016-10-11 10:19 PM
TMA_80 wrote:I've never understood why, this many versions in, we've never had such a tool which wouldn't just be important for Roof drains but even Floor drains which we have to show on our plans as standard, and which have be reflected on Section drawings as well, where they appear.
‎2016-10-12 12:15 AM
‎2016-10-27 08:37 PM
