Daniel Kovacs
ARCHICAD 21 Update 6000 Preview released
Dear All,
Today we have made the preview version of our next ARCHICAD, BIM Server and BIMcloud 21 Updates available. We have tested the packages with the AUS, INT, NZE, UKI and USA versions so far and they all passed our Quality Control.
This package is only compatible with the above language versions. If you attempt to install it on a different language version, you will get an error message about this.
We will create a Public update compatible with all language versions in a few weeks time. If the two will differ, it will be possible to update from the Preview package to the Public one without a problem.
You can read the Release Notes and download the packages from here: Regards,
Daniel Alexander Kovacs
GRAPHISOFT
37 Replies 37
I have been having serious issues with the railing tool since the update.
2018-03-30-23-07-48-8176 bug id
edit:
I can reproduce a crash on multiple files it seems to be the railing plus roofs. I do use a modified library, however i do not or have not modified the railing tool objects. 5021 had no issues with this
Eduardo Rolon
DWG Translator comes up blank and the only way to exit is to force quit AC
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I just tried opening the DWG Translator on my Window machine to see if I got the same result, and my outcome was a crash/bug reporter. I can understand some exotic sequence of keystrokes causing a crash, but is it really too much to expect that GS would try each of the basic menu commands to see if it works before labeling testing "complete"?
Richard
AC26 (since AC6.0), Win10
DGSketcher
Legend
Dragging dimension text placed "within line" moves the text but leaves the broken dimension lines.
Same her opening the DWG Translator on my Window machine: a crash/bug reporter.
Hasn't Archicad always done this?
DGSketcher
Legend
Barry, I have checked back and as you have indicated it would appear to be a legacy issue. Not sure why I've just picked up on it, perhaps the complexity of dimensions on my current project. I still think it's something that needs fixed. These kind of basic bugs should have been eradicated a long time ago...
Daniel Kovacs
edit:
Could you elaborate on this a little bit? I tried to reproduce it by placing a roof and a railing associated on it, but it didn't crash for me. I would need to reproduce it in order to fix it.
What platform are you on? Windows 10?
What are the steps you have to make to reproduce the crash?
When does it crash? when placing a railing? When editing its settings?
Could you send me a file that you can reproduce it with (in a PM), and also tell me the exact steps I have to make in the file to reproduce it?
Thanks,
GRAPHISOFT
Daniel Kovacs
Richard wrote:
I just tried opening the DWG Translator on my Window machine to see if I got the same result, and my outcome was a crash/bug reporter...
Hi guys,
Thanks for the report! I don't know how we missed this, but I will make sure we fix this before the release.
Thanks,
GRAPHISOFT
