ā2018-03-28 04:31 PM
ā2018-04-04 05:59 PM
dkovacs wrote:Personally, I would find it helpful to know if there is an easier way to roll back the installation to the previous version than doing an uninstall/reinstall/update. This is a huge time waster. If so, it should be posted in "Help."
Thanks for the report! I don't know how we missed this, but I will make sure we fix this before the release.
Thanks,
ā2018-04-05 12:49 AM
dkovacs wrote:I am on mac osx high sierra, It must be my file or something with my library. I completely uninstalled archicad and reinstalled it and still the same issue in all my files. I will try one more time otherwise i will have to send my library and a file.SenecaDesignLLC wrote:Hi,
I have been having serious issues with the railing tool since the update.
2018-03-30-23-07-48-8176 bug id
edit:
I can reproduce a crash on multiple files it seems to be the railing plus roofs. I do use a modified library, however i do not or have not modified the railing tool objects. 5021 had no issues with this
Could you elaborate on this a little bit? I tried to reproduce it by placing a roof and a railing associated on it, but it didn't crash for me. I would need to reproduce it in order to fix it.
What platform are you on? Windows 10?
What are the steps you have to make to reproduce the crash?
When does it crash? when placing a railing? When editing its settings?
Could you send me a file that you can reproduce it with (in a PM), and also tell me the exact steps I have to make in the file to reproduce it?
Thanks,
ā2018-04-05 01:54 AM
SenecaDesignLLC wrote:dkovacs wrote:I am on mac osx high sierra, It must be my file or something with my library. I completely uninstalled archicad and reinstalled it and still the same issue in all my files. I will try one more time otherwise i will have to send my library and a file.SenecaDesignLLC wrote:Hi,
edit:
Thanks,
If i place a railing associative or not for more than three consecutive clicks it crashes, if i modify a roof that has it attached it crashes, literally any modification i do to the railing crashes. I will update once i have tried again
ā2018-04-05 02:59 AM
Richard wrote:When I remember, I duplicate (copy) the Archicad program folder and then re-name it with the original build.
ā2018-04-05 03:58 AM
Barry wrote:i am going to try this with mac now. this will make testing things so much nicer!!!!Richard wrote:When I remember, I duplicate (copy) the Archicad program folder and then re-name it with the original build.
Then update the program.
If I ever need to go back I can just manually run the version I want or I can rename the folders to have the one I want run automatically (i.e. associated with PLN file type).
ā2018-04-05 04:35 AM
SenecaDesignLLC wrote:Barry wrote:i am going to try this with mac now. this will make testing things so much nicer!!!!Richard wrote:When I remember, I duplicate (copy) the Archicad program folder and then re-name it with the original build.
ā2018-04-05 05:27 PM
Barry wrote:Thanks, Barry! Although I guess I'm surprised that such a basic approach would work. I always assumed that there would be stuff buried in the Registry or User Data files somewhere that would cause problems.
ā2018-04-05 08:24 PM
another Moderator
ā2018-04-06 01:32 PM
ā2018-04-12 12:44 PM
SenecaDesignLLC wrote:Hello All,
edit:
