2017-05-02 03:52 PM
2017-06-15 05:14 PM
2017-06-19 06:35 AM
2017-06-19 08:53 AM
mthd wrote:I need a new monitor stand.
Yay ! We are still getting the boxes for 21 and for future versions the box is an optional extra.
2017-06-19 10:37 AM
2017-06-19 11:31 AM
mthd wrote:Yeah, the last decent door stop was version 6.5 that had about 6 printed manuals in it.
Oh ! Is that what the box is for Barry
2017-06-19 12:24 PM
2017-06-19 07:23 PM
stefan wrote:Let's also not forget that GS have a tendency and habit of introducing these big new tools every couple of new versions, and then abandoning any further development on them when they direly could use improvement.
You never forget the feeling when you receive your first ARCHICAD box... Even though all you need today is pure digital: download, reference documentation and a software license.
On another note: let's not forget that GS has the tendency to develop features that take more than one release to be integrated widely and you may just see the full impact over a few versions e.g. glimpses of classification which were already in place in AC20 (together with the property system) and which will hopefully continue in the future, to not only cover element & zone classification.
And while we're at it... maybe it's time to get rid of the "tools" a bit more: it's not simply a "Wall" with the wall tool or a "Column" with the Column tool... There areWith the classification you are more free to give them any meaning which makes sense in the project and not be restrained by the initial geometric behaviour.
- parametric objects (Window, Door, Object, Skylight...)
freeform geometry (Morphs, Shells, Meshes),
planar elements which can (or should be able to) host openings (Walls, Roofs, Slabs) and which can be layered
Profiled elements (Wall, Beam, Column, now also in Objects)
Hierarchic elements (Curtain Wall, Stair, Railing).
This is also more in line with current, complex projects and what is happening in other software too.
2017-06-20 10:38 AM
Bricklyne wrote:In terms of shell, just being able to adjust the angle of edges like you could do with slabs/roofs and for shells and multiplane roofs to be able to allign the textures so your fills line up in elevation and plan the same way would be a nice start
(*Similarly a Morph 2.0 and a possible Shell 2.0 would be nice, following in the example of Teamwork 2.0 which was a significant leap from the original. Just things to consider.)
2017-06-20 10:34 PM
2017-07-03 11:32 PM
