You are close. To move a specific distance from an object or known node the procedure for Feet+Inches is:
1. Place cursor on top of point, intersection, etc
2. To move to the right type X(dist)+ for example to move 2"-0" to the right you would type X2+
3. To move to the left of the point is X(dist)-- or X(dist)-+ because of using english units you need to use 2 dashes (minus signs). For metric units or decimal feet you only need 1 dash.
This works for coordinates in X, Y and Z.
For other angles you can rotate the drawing and then use the regular coordinates.
The other option is to grab the end point and after having the guideline in the correct direction use Shift+R and type the distance.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
another Moderator
