2022-06-05
07:42 AM
2025-01-30
04:26 PM
Molinda Prey
After create opening, the opening finish of the lower wall and the location wall is different.
I want to do it together, what should I do?
If not, what should I use instead of create opening?
It consists of two walls on the first and second floors.
2022-06-06 06:19 AM
Do you mean you need to create one opening that penetrates the two walls n first and second floors?
2022-06-06 06:35 AM
yes
Ask for a wall for each floor.
2022-06-06 06:45 AM
You can place opening from opening tool and define its sizes and the geometry method ( here horizontal) then by hovering over your wall seeing how it will look click to place the opening.
2022-06-06 12:16 PM
You know what I want to put together because this part is different, right?
2022-06-06 04:00 PM
I draw all walls like that as two story walls. Much easier and likely how it will be constructed.
2022-06-06 04:30 PM
A more detailed and lengthy explanation is needed.
I have to use translate.google.com, so the translation doesn't make sense for sentences that are too small.
If you use images from time to time, I would be more grateful.
