clauds1223
Align tool
Hi there,
Is there any tool in archicad where I could align the edge of the wall to the grid line (refer to image).
5 Replies 5
AllanP
if you select the wall and the grid, you could use the align Horizontal right command.
Edit -> Align -> Horizontal right
I hope this helps.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
alemanda
yes, by the way it's not a stretch. You don't stretch the wall up to the gridline ...
With "align" in archicad you move the objects to align each other, considering their bounding boxex.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Botonis
Mentor
The align command takes in consideration the closest point. The object will not align by rotating based on its bounding box but just move until it reaches the aligning line.
clauds1223
Yes but I feel like this process takes too long. Are there any shortcuts?
Jan Millan
You can create custom keyboard shortcutsfor almost any command/tool you want.
The commands under the Edit menu are some of my most frequently used keyboard shortcuts, so I mapped them around the same area of my keyboard. To give you an idea of what's possible, here are some of the shortcuts I have been using for these commands for many years now:
Command KBS
Distribute Along X [
Distribute Along Y ]
Distribute Special \
Align Horizontal Left ⌥[
Align Horizontal Right ⌥]
Align Horizontal Center ⌥\
Special Align ⇧|
Bring Forward ⌃[
Send Backward ⌃]
Bring to Front ⌃⇧[
Send to Back ⌃⇧]
Reset Default Order ⌃⇧|
Jan Millán
Senior Technical Support Engineer, Graphisoft
Graphisoft Certified BIM Manager
