Annoying bug when editing Complex Profiles
gpowless
Since the last update every time any composite is edited many unrelated composites automatically adjust their height even though the story heights have not changed. Others will sometimes show offsets from the story even though they have not been changed from their default story setting.
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
11 REPLIES 11
gpowless,
Can you provide the steps to reproduce this bug.
I am sure Graphisoft would be interested in it if we can give them steps to reproduce.
gpowless
Simply making any edit of the complex profile results in the change except the in the wall dialog it still shows it as being linked to the upper storey. To correct it I havve to open the wall tool, change the storey to be linked and then change it back to the linked storey. Then it fixes to corrrect adjustment.
The anomoly occurs on multiple walls after 1 single complex profile has been edited.
