AndorSzoke
ArchiCAD 18 Update 4020 is Available
We have released ArchiCAD 18 Update 4020. It is currently available through the automatic update system for the INT, USA, AUS and GER language versions. Further language versions will be enabled as they pass Quality Control. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC18/AC18-3006to4020-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
46 Replies 46
Dennis Lee
Ok, this is really frustrating. I had so many crashes with my iMac, I gave up on using it as a workstation, and am now trying to use it as a Bim Server. I installed the USA 3006 version alright, but when I try to update to the 4020, no matter what I try the installer only looks for ArchiCAD 18. It says archicad is up to date, and gives me an option to browse for another locaiton for 18, but does not update the Bim Server 18.
Please help?
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Ted Taylor
AndorSzoke wrote:
Maged wrote:
Does anyone experience ArchiCAD 18 build 4020 crash on Mac OS 10.10? I stopped working with AC18 and get back to AC17.
Dear Ted, Dear Maged,
I wonder if there is any chance that you have the problem documented in the Yosemite article on HelpCenter:
http://helpcenter.graphisoft.com/technotes/operating-systems/mac-os-x-10-10-yosemite/#Important_note...
If not, can you send in your crash reports and send us the Crash-ID displayed at submitting?
I never loaded the beta version of Yosemite, but I tried some of the steps noted above without results. After trying several other things including a clean install (after a complete uninstall of everything that could be uninstalled) of Archicad 18 (3006) and installing a new version of Yosemite on a separate start up disk which all resulted in the same behavior, Crash on startup. I have reverted back to Maverick and (3006) which does not crash. I have sent the crash reports along with the crash-ID into Tech Support but they have not responded, which I find frustrating.
Ted
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Marton Kiss
Please help?
Dennis,
maybe some registration information is missing and as a result the update installer cannot find your BIM Server. Try to run the original BIM Server installer. This will run in repair mode and re-create everything that might be missing.
After this hopefully you will be able to patch it with the latest update.
Regards,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Marton Kiss
Ted wrote:
I never loaded the beta version of Yosemite, but I tried some of the steps noted above without results. After trying several other things including a clean install (after a complete uninstall of everything that could be uninstalled) of Archicad 18 (3006) and installing a new version of Yosemite on a separate start-up disk which all resulted in the same behavior, Crash on startup. I have reverted back to Maverick and (3006) which does not crash. I have sent the crash reports along with the crash-ID to Tech Support but they have not responded, which I find frustrating.
Ted,
we identified the source of this crash, which appears to come only on certain computers running OS X 10.10.
I asked our US team to get in touch with you with some instructions to work around this problem until a proper solution is available.
Regards,
Marton
Marton Kiss
GRAPHISOFT
Ted Taylor
Marton wrote:
Ted,
I asked our US team to get in touch with you with some instructions to workaround this problem until a final solution is available.
Regards,
Marton
Thank you, the US team reached out to me and the work around worked. I appreciate everyone's efforts on this.
Ted
Ted Taylor
Atlanta, GA , USA
OS10.14.2,
Latest Archicad 22
Thomas Holm
Found out today that the Publisher non-Postscript-compatibility issue still lingers in update 4020. see http://archicad-talk.graphisoft.com/viewtopic.php?p=235845#235845
I wonder what the excuse is to not support all fonts that the OSX system supports?
Martin Jules
Mentor
Does the latest version of ArchiCAD 18 work properly on OX S Yosemite, version 10.10.2 ?
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
Steve Jepson
JaredBanks wrote:
So any insight as to why this is an Update and no longer a Hotfix?
This is just more SSA coercion.
If not signed with SSA:
No free upgrade will be given
No Dongle replacement
Paid technical support applies
Whereas there is no charge for the Hotfix and you don't need the SSA for that reason. Which for some is the only reason.
Steve Jepson
Were is the AC 18 build 5614 hotfix ?
Aaron Bourgoin
Steve,
how did you come by this info. I just signed up for the SSA, but don't seem to have any special access save for being able to download the surfaces bundle.
it's been a while since we;ve seen a new build.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
