ArchiCAD 18 Update 4020 is Available
AndorSzoke
We have released ArchiCAD 18 Update 4020. It is currently available through the automatic update system for the INT, USA, AUS and GER language versions. Further language versions will be enabled as they pass Quality Control. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC18/AC18-3006to4020-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
46 REPLIES 46
Aaron wrote:
Steve,
how did you come by this info. I just signed up for the SSA, but don't seem to have any special access save for being able to download the surfaces bundle.
it's been a while since we;ve seen a new build.
I have my secrets.
What info? This ?
Aaron - Ummmm.....Re: Surfaces Bundle? Where can I download this? Please share.
Respectfully - Greg
BIM Components.
If you have an SSA then in Archicad when you go into the surface settings dialogue you will see a link to the SSA surface download.
Similarly, you if you have the Maxwell plug-in for ArchiCAD you can access Maxwell materials through the same Surface Settings menu.
if you want the really good materials for use with a really good rendering engine.
Barry / Steve-
Thank You!
Greg
The latest AC18 hotfix is not released yet, but from the answer of the GS Tech Sup guys I guess it is not far from being released.
Hey, I'm currently using ArchiCAD 18 4020 build on Apple MAC OS X Yosemite and am currently having problems with publishing any drawings of all types, PDF's and DWG's.
During the process, when I hit the publish button the publisher dialogue box showing the drawings being published does not appear and the publisher button stay's dark grey. After the publishing is finished then ArchiCAD freezes up and cannot to work on the drawings.
Also I forgot to mention I have to force quite ArchiCAD to start to draw or navigate again...
Can anyone provide any light to this issue or even assist in solving this problem?
That would be a great help... Thanks
SOLEK
The latest build is now 6000.
Have you tried that?
Hey Barry,
I did not receive any notification to your message/response to my post. To answer your question, I have recently updated the program to AC18 Build 6000. Hoping that this would solve it, the problem still remains. When I publish either DGW or PDF, the publisher dialogue box does not appear after clicking on the Publish Button and the button turns dark grey as shown in the screen shot attached in the original message. Every time I publish I have to force quite ArchiCAD and restart it...Still baffled with this problem. Have you or anyone else had the same problem...
SOLEK
