2013-10-30 10:00 PM
2015-03-27 09:41 PM
2015-03-28 01:49 AM
laszlonagy wrote:I think you'll find the growth has been in engineering, construction, Acquisitions, and forced subscriptions, can you honestly say Architecture sales has tripled?
Did you guys know that Nemetschek is now a billion euro company? (almost 10 million shares at over 120 euros apiece):
http://www.tenlinks.com/news/nemetschek-dividend-up-23-to-euro-1-60-per-share/
Its share price nearly TRIPLED in the last two years.
http://www.bloomberg.com/quote/NEM:GR/chart
When a product is part of a billion euro company that is growing nicely and when a product is one of the things driving that growth, that product (and the company developing it) is not dying, at least in my book.
2015-03-28 01:50 AM
2015-03-29 07:25 PM
2015-03-31 12:04 AM
laszlonagy wrote:
DesignEngineerBIM,
Could you please point me to the documents that support your claim that Nemetschek's growth is in Engineering and Construction?
laszlonagy wrote:Check out what other members in the group are doing..we will see where the growths been soon.
To my knowledge, the biggest brands within Nemetschek are ArchiCAD, Vectorworks, Allplan, all architectural/design focused (both VW and Allplan have other modules as well), so this is a curious claim to me.
Also, what do you mean by this forced subscription? ......
Yes, acqusitions may have a part in it, such as the DDS and Bluebeam acquisitions last year.
laszlonagy wrote:Again other members in the goup are very good at talking it up but IMO I wouldnt be following their lead if I were you...
By the way guys, I am not blind or something, I am just optimistic about the future of ArchiCAD and Graphisoft. I just find that better than being always negative or seeing the possible bad.
I mean, if we want ArchiCAD to succeed, why bother concentrating on the negative?
2015-03-31 01:01 AM
Again other members in the goup are very good at talking it up but IMO I wouldnt be following their lead if I were you...Could you explain?
2015-04-01 02:42 PM
2015-04-05 03:02 AM
2015-04-07 06:07 AM
Bruce wrote:1. For the UI Improvement we would suggest having less dialogs an object dialog and have the parameters editable as a user special clicks or hovers over that part of the object, more direct editing in direct relation to other model objects. In addition the 3d editing environment needs improvement with a more robust navigating and orbiting feature set.
I know that's a controversial subject line, but I believe it's true. Not because I want it to be, but because Autodesk is an advancing monster; ArchiCAD firms are switching to Revit, and Revit-based firms are buying ArchiCAD firms...and switching them to Revit.
ArchiCAD is a great program, but if it keeps going the way it is, I fear it will gradually dwindle until it's finally gone. On a level playing field, it comes out more or less even with Revit (I have done a detailed analysis that has been vetted by Revit experts) - but it's not a level playing field.
In my opinion, Graphisoft needs to do a handful of things to even the odds (yes, I will compare to Revit, as that's the main competition):
1. Rebrand & revamp the UI: CAD is an obsolete term. Even though ArchiCAD was BIM way before the term was even coined, I think the "CAD" in the name does it a disservice. Also, the user interface is old and tired. Should it go to the ribbon? No way. Should it be brought into the 21st century? Absolutely - there are plenty of excellent examples out there. Blender, a free 3D program, is undergoing its second UI redesign in about 5 years. If Blender can do it, Graphisoft can.
2. Introduce type-based elements. At the moment, pretty much everything is instance based. If you place 100 doors 900mm wide throughout the project, you have to select and change every single instance (this is an example, so please don't tell me the workarounds - that misses the point). Essentially, this is extending the attributes database to other objects. This makes project-wide changes so much more consistent, with no fear of missing an element.
3. Easier creation of parametric custom content: A beginner user in Revit can create a basic parametric object by using geometry and dimensions. It is intuitive and accessible. This does have its limits, but GDL is completely inaccessible to any but the advanced user with a programming mind...something architects and drafties generally don't have - otherwise they'd be programmers. A mix of the two would be extremely powerful - maybe an interface similar to Visual Basic, or Grasshopper? Not only for 3D elements, but also for 2D labels.
4. Better labelling & keynote tools: At the moment it's one label per element per view. What if I want to tag more than the ID? What about material, thickness, height etc. Revit is excellent in this regard, and also in the ability to create your label format as specific as you please. Key notes are also critical.
These are only four key improvements that I think are critical. There are many others that I could list, but this post is already too long. I say the above not to criticise ArchiCAD, but to try and help (misguided however it may be).
I could be wrong - I would be happy to be wrong...but the Autodesk monster is advancing...
These changes should be done the Graphisoft way: not to match what Revit does, but to equal and better it.
2015-04-16 11:20 AM
