2013-10-30 10:00 PM
2015-04-16 03:33 PM
blobmeister wrote:That's the impression I got at first but be aware that some features were already revealed and available as an revit 2015 update(as usual with Autodesk and that killed the suspense). anyway, I agree, our expectations were high...
If there is one software that is on the verge of death than that is Revit. Revit 2015 was already a horrible release and Revit 2016, what just came out is even worse, with absolutely no improvements, no new feature or enhancements. They just released Revit 2015 and changed the name to Revit 2016. Can you imagine Graphisoft releasing Archicad 19 that is exactly the same as Archicad 18 except for the name change?
People, count your blessings. Revit is finished and almost gone.
2015-04-17 03:43 AM
blobmeister wrote:Fun narrative, but not a true one.
2015-04-23 07:05 PM
strawbale wrote:And how exactly would you like it to work? If someone asks me "how do you find doors and windows in AC?" I would probably say "Tag your elements using their ID when you are creating them, then use Find & Select to... errr... find and select them". If they say... "oh dear!... that's a workaround" it's probably because they don't understand that is one of the ways the software is designed to work in the first place (because, of course, there are other ways to find them). I think AC could be more friendly in some aspects, but it is friendly enough for people to grasp the whole BIM concept.methy wrote:And therein lies the whole issue with the current Archicad setup.
changing multiple doors is easy if you know how to set up your files correctly
for example using "Element ID" & "Find & Select"
you can do exactly what you want provided you have an ID system set up
If AC was designed to be user friendly you wouldn't need to know or even use these kind of esoteric work around solutions.
2015-04-27 01:22 AM
sinceV6 wrote:I do strongly agree, the future is (already here) definitely BIM based server, data rich multiphysics, app drive internet data, delivered to forums,clients, designers, builders, engineers and most importantly to Building Authorities.
Hi.
Back on topic... and it looks that GS can't let old things and tech go and move forward.
2015-04-29 06:39 PM
2015-04-30 12:39 AM
2015-04-30 03:28 AM
2015-04-30 10:12 AM
Ivan wrote:
I also think there are some issues that are definitely worth considering when it comes to the usability of Archicad.
Assemblies are an extremely important feature. Creating objects that have a nested structure with subobjects is possible with GDL, yes, but the level of abstraction that forces into the user makes it hardly usable for most. Look at how it works in Sketchup, for example: you just click your way into the tree of nested components and groups and can reorganize it and redefine it with the outliner window... With something like that, man, components / blocks / objects in archicad would be awesome!!. Imagine being able to redefine on the fly a subcomponent of an assembly... Also, the ability to explode objects getting the original componentes (something other threads have treated) comes into play as something fundamental. Again, that outliner window in Sketchup would be fantastic to have within archicad to see the hyerarchical structure of models and objects...
Bentley has a remarkably good xref management in which nesting can be very easily organised. Archicad tools for that are, ehem, mostly non existent. The way it handles it in hotlinks with only one level of nesting is poor IMHO.
The concept of the model as a hyerarchical assembly is getting more and more important as modularity is. The ability to very easily create assemblies, organise them, redefine them, etc., is key. I mean, look at IFC, it's the same tree concept.
Trimble is heavily investing in "BIMming" Sketchup and they are producing remarkable software on it while keeping the usability of SK, I would say that is a good example.
All this "tree" stuff leads - inevitably - to nodes...
Regarding "parametricity", I would say that the best path is interoperability. I don't think that there's one BIM software "to rule them all". We need to be able to talk to the other guys. Grasshopper will find a way to Archicad (geometrygym tools by Jon Mirtschin have been talked about in other threads) when it is needed. Certain parametrical objects are very useful in certain scenarios, I think it's great to have specific tools to deal with them as long as I can bring them into the main model for documentation and submittal.
I think that IFC-centric bim means that whatever you use to produce the models does not matter, as long as the information is there for me to access it, account it, etc. AC role as an architectural BIM should stress the - already very good - interoperability options of the software and the usability of it.
Excuse the length...
2015-04-30 04:39 PM
strawbale wrote:I couldn't agree more. As someone put it in another thread, Archicad is a friendly modeler but unfriendly object/component creation and managing tool...
AC is a great program and now has a multitude of very powerful features that have been introduced over the years . The problem I have is that the UI has not been changed or adapted to integrate all these features and tools in a manner that is unified and intuitive.
2015-04-30 07:33 PM
