2021-09-03 11:25 PM
Hello, I am trying to understand what is causing the blurriness in our print outs and PDFs of a tile hatch - see the left hand side of the screenshot below. This seems to be a very intermittent problem, but very annoying and makes the drawings look ugly. Sometimes our hatches print fine, and then sometimes this happens, and I really don't understand what the cause is.
So in this particular instance:
- The tile is modeled as a slab
- The top surface of the slab is overriden with "Field Tile" Surface
- The surface "Field Tile" uses a fill "Paving Windmill"
And then the view is placed on a layout at 1/4"=1'0" scale.
Screenshots attached. Any help is appreciated!!
2021-09-06 03:31 AM
Are you using the inbuilt publisher or are you using a 3rd party PDF plotter?
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2021-09-06 05:45 AM
Hi Lingwisyer I am using the regular publisher sets
2021-09-08 09:44 AM
2021-09-10 04:22 PM
Hi Edi,
Thank you very much for the question! This is a rare one!
I'm wondering if there is a constant way to reproduce the issue? If you change the type of fill or the pen color, does the issue persist on the same slab?
I saw Steve posted a screenshot before me. What if you select the Element Pen, does it fix the issue?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
