2021-09-27 03:59 PM - edited 2021-09-27 04:02 PM
Hi I'm struggling to design this simple but atypical window. do you have some recommendation how to reach this shape ?
Solved! Go to Solution.
2021-09-27 06:21 PM - edited 2021-09-27 06:22 PM
Hi
You can try to create the window as a rectangular one (without the diagonal side) and then Convert selection to Morph(s). Once you have done that, modify as desired, select it all and go to File Menu> Libraries and Objects> Save Selection as...> Window... as described on this article: https://community.graphisoft.com/t5/Design-articles/How-to-create-Custom-Window/ta-p/303432
Regards
2021-09-27 04:01 PM - edited 2021-09-27 04:03 PM
Hi
Regards
2021-09-27 07:11 PM - edited 2021-09-27 07:12 PM
In addition to Ricardo's suggests - which is great for a one-off - you can use the Libary Part Maker (LPM) add-on to create a custom window with that shape that is parametric.
This is the link to the US version of LPM...site search seems to be based on my data, so you'd have to modify for your country-specific (SWE) version:
https://graphisoft.com/us/downloads/addons/LPM/
And, this topic might be helpful if the created window does not load:
https://community.graphisoft.com/t5/Design-forum/Library-Part-Maker-window-help/m-p/291029
2021-09-27 09:08 PM
Hello @Vojtech Slavik,
I would like to suggest this Add-On for the development of atypical windows:
https://graphisoft.com/downloads/addons/archiglazing
2021-09-28
03:44 AM
2021-10-03
01:23 AM
Also you can try searching in BIMComponents for "polygonal window" in the window settings search option.
I have not used this object but it may do what you want.
2021-09-28 07:43 AM
The very simplest answer I know is to use the CI Tools library, which allows exactly that window shape out of the box.
2021-09-28 08:52 AM
I can't see results like yours ? Is't version of Archicad ?
2021-09-28 09:01 AM
I think you might be searching in the object tool.
You need to be in the window tool.
2021-09-28 11:09 AM - edited 2021-09-28 11:51 AM
I found this video and it's like you said - easy way how to do it
Video : https://www.youtube.com/watch?v=HtikuYmt2cU
