Atypical window shape
Hi I'm struggling to design this simple but atypical window. do you have some recommendation how to reach this shape ?
Skärmavbild 2021-09-27 kl. 15.54.59.jpgSkärmavbild 2021-09-27 kl. 15.58.34.jpgIMG_6223.jpg
AC 7 - 27 SWE
MacBook Pro, M4 Pro
1 Solution
Ricardo Lopez
Hi
You can try to create the window as a rectangular one (without the diagonal side) and then Convert selection to Morph(s). Once you have done that, modify as desired, select it all and go to File Menu> Libraries and Objects> Save Selection as...> Window... as described on this article: https://community.graphisoft.com/t5/Design-articles/How-to-create-Custom-Window/ta-p/303432
Regards
Ricardo López, M. Arch.
Go to post
16 Replies 16
AC 7 - 27 SWE
MacBook Pro, M4 Pro
Ricardo Lopez
Hi
Regards
In addition to Ricardo's suggests - which is great for a one-off - you can use the Libary Part Maker (LPM) add-on to create a custom window with that shape that is parametric.
This is the link to the US version of LPM...site search seems to be based on my data, so you'd have to modify for your country-specific (SWE) version:
https://graphisoft.com/us/downloads/addons/LPM/
And, this topic might be helpful if the created window does not load:
https://community.graphisoft.com/t5/Design-forum/Library-Part-Maker-window-help/m-p/291029
Qualifa
Hello @Vojtech Slavik,
I would like to suggest this Add-On for the development of atypical windows:
https://graphisoft.com/downloads/addons/archiglazing
Proud member of UNION.ARCHI Network
Also you can try searching in BIMComponents for "polygonal window" in the window settings search option.
I have not used this object but it may do what you want.
Paul King
Mentor
The very simplest answer I know is to use the CI Tools library, which allows exactly that window shape out of the box.
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
I can't see results like yours ? Is't version of Archicad ?Skärmavbild 2021-09-28 kl. 08.49.50.jpg
AC 7 - 27 SWE
MacBook Pro, M4 Pro
I think you might be searching in the object tool.
You need to be in the window tool.
I found this video and it's like you said - easy way how to do it
Video : https://www.youtube.com/watch?v=HtikuYmt2cU
AC 7 - 27 SWE
MacBook Pro, M4 Pro
