ā2016-02-22
01:03 PM
ā2023-05-24
08:42 AM
Rubia Torres
ā2016-02-22 02:09 PM
ā2016-02-22 08:29 PM
ā2016-02-23 12:30 PM
laszlonagy wrote:I do not mean the on screen view connections, I mean the feature Auto Intersection, that automatically intersects reference lines of walls (and possibly beams, I don't use that tool too much) by extending or shortening them as needed. I prefer to draw the reference lines as I want them to be (sometimes I do not want them to connect as it leads to unwanted results in 3D), so I keep turning it off. Every day again.
I think the state of On-Screen View Options (including the Clean Wall & Beam Intersections toggle) is a Project-specific setting, not a Work Environment settings.
But this also means that it should be saved with the Project and its state should be remembered by ARCHICAD when it later reopens the file.
So if that does not happen then it may be a bug.
I tried it and it works for me.
You can try one thing: since it is a Project-specific setting, every time you start a new Project it will start it based on the Project settings stored in the Template file you choose for your new project. So in theory you could open the Template file, change this setting, then resave the Template file under the same name.
From there on new Projects file based on that Template file should have this toggle turned off by default.
ā2016-02-23 01:46 PM
ā2016-02-23 01:53 PM
laszlonagy wrote:Thanks Laszlo
I see, you mean the Options\Auto Intersection menu option.
I think that is also supposed to be a setting that is saved with a Project, not a setting that is saved with the Work Environment.
But I tried both and it seems to me that it is not saved with either.
So this is probably a bug that the state of the Auto Intersection toggle is not saved with the Project.
I will report this to GRAPHISOFT.
ā2016-02-23 03:16 PM
ā2016-02-23 03:30 PM
ā2016-04-04 12:35 PM
ā2016-05-28 08:17 PM
