Auto select on redo
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-10-10 11:47 PM
‎2012-10-10
11:47 PM
Daniel del Nido
AC6.0-AC19 AUS; Windows 8 Enterprise 64bit
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-10-13 02:10 PM
‎2012-10-13
02:10 PM
Can you give a specific instance and step that we can reproduce? When I try it, it works for me.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-06 02:29 AM
‎2012-12-06
02:29 AM
Sorry for the delay in responding. A really basic example is that if I use the magic wand to create a polyline that follows the out line of a slab, then want to select that polyline, I have become accustomed to just performing an undo/redo to select that polyline (saves cycling through all elements located at that point). I find that the polyline is not automatically selected, as it used to be.
Daniel del Nido
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-07 11:36 AM
‎2012-12-07
11:36 AM
It is interesting, it works for me:
1. Select Polyline Tool.
2. SPACE-click Slab outline, Polyline is created.
3. Undo.
4. Redo.
5. Polyline is selected.
3. Undo.
4. Redo.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-11 04:47 AM
‎2012-12-11
04:47 AM
catrasca,
If you have imported your Work Environment in from a previous version I recommend you first save it and then switch to the Standard Profile 16 to see if that rectifies the trouble.
Work Environment Help Doc
Best regards,
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Tutorials
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-12 01:36 AM
‎2012-12-12
01:36 AM
"NCornia" wrote:
catrasca,
Tried this, still no luck. I generally set up all Work Environment profiles from scratch with new realeases so I can include any new features. Any other ideas?
Daniel del Nido
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-12 11:57 AM
‎2012-12-12
11:57 AM
Maybe a graphics card driver problem? This is just a wild guess.
Try to update to the latest drivers.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-12-12 04:16 PM
‎2012-12-12
04:16 PM
catrasca,
An undocumented command is the New & Reset All command. Save your current project; go to File / New and before clicking the New command hold the Alt key (Windows) or Option key (Mac) and the New Command will transform into the New & Reset All command. By clicking this a new project will be created but also some temporary preferences will be cleared out. You can then re-open your project and try the undo-redo operation.
If this does not work then export your current Work Environment and Back-up your local TWData folder and perform a full Preferences Cleaning procedure. http://www.archicadwiki.com/PreferencesCleaning
HTH
HTH
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
Tutorials
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-03-11 02:05 AM
‎2013-03-11
02:05 AM
Thanks Nicholas. Problem fixed - should have know the new & reset all would do the trick! Appreciate the help.
Daniel del Nido
