2005-04-06 03:34 PM - last edited on 2023-05-26 11:43 AM by Rubia Torres
2005-04-08 09:03 AM
oreopoulos wrote:Select the doors and windows in the marquee if you want to work on them.
When i select a region with the marquee and try to manage element ID for doors and windows then the change id button is INACTIVE. When i dont have a region selected everything is ok.
For walls beams... the marquee works ok.
2005-04-08 10:08 AM
2005-04-08 10:26 AM
oreopoulos wrote:Did you try Find&Select in 3D?
I use the thick marquee, to act on all stories.
2005-04-08 10:41 AM
