Steve Jepson
Bad cleanup
interesting that I can't get these walls to clean up properly.
4 Replies 4
Steve Jepson
Steve Jepson
does not seem to matter if reverence lines are one side or the other.
rocorona
Try using a single thin walls, crossing the bold one, instead of two.
If you need two separate walls, put the joint slightly OUT of the bold wall.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Steve Jepson
Yes, that works fine for a plan view fix. It messes up the 3d view and schedule. Actually I don't need the accuracy of the model and schedules anyway. I just think it should clean up with out having to trick the program.
