rob2218
Beam Profile creating stairs? how to make riser lines read?
how do I make the lines in 3D that create the edges of the beam profile "read" in 2D?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 Replies 4
Ernest Atanasiu
Turn it into a morph and control line visibility.
AFAIK there is no control in profiled beams for lines that make up the profile.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
rob2218
Exactly!!!!....why don't the "beams" with stepped situation actually SHOW how they are in plan?
For Pete's sake...they show how they are in 3D, in section..in elevation...........WHY not in plan view?
i>u
Edgewater, FL!
SOFTWARE VERSION:
No time right now to test, Rob... but if you use the Wall Tool with the same profile to create the stairs, do the wall floor plan display options give you any better appearance? (Being a wall, the layer for the 'stairs' must have a different intersection priority than adjacent walls to prevent auto cleanup.)
rob2218
I'll check the graphic 2D display lines with the "wall tool" instead.
Stupid that a beam simply WILL NOT show the 'real' lines it's projecting...........just dumb.
i>u
Edgewater, FL!
SOFTWARE VERSION:
