2007-03-20 10:33 AM
2007-03-20 03:17 PM
2007-03-20 04:24 PM
2007-03-20 05:02 PM
TomWaltz wrote:... and join them in the layouts if needed.
I'm not aware of any way to bend a section marker. You can offset it, but not bend it.
I suspect you would need to make different markers for each angle.
2007-03-20 11:13 PM
2007-03-21 12:19 AM
Djordje wrote:This is true but there are times when it would be very, very useful to be able to create a curved/bent elevation.
Elevation is a planar projection by definition; therefore it should not bend ...
2007-03-21 12:55 AM
2007-03-21 11:02 PM
owen wrote:
... it would be very, very useful to be able to create a curved/bent elevation.
Such as drawing flattened/unrolled elevations of a curved curtain wall....
2007-03-22 12:36 AM
Philip wrote:The facade contractors I have worked with generate shop drawings of exactly what I am talking about - a single, flat (i.e fake) elevation of a curtain wall which curves in several places. It is the only way to clearly lay out all the panel types along a facade. We provide the same type of elevations in our tender sets (together with the traditional 'true' ones) as we have found it easier for everyone to understand just how it all fits together.owen wrote:
Yes it would be a nice feature in theory BUT I cannot see it being practical for two reasons.
1. I get enough stupid questions from contractors without giving them "false" elevations to try and work with!
Philip wrote:Whilst it is difficult to achieve I disagree that it can't work - its just a matter of programming. Yes there would need to be a line along which everything flattened is a true dimension. Things infront/behind that would be stretched/compressed to take account of the horizontal extent.
2. Unless the SE has a zero horizontal extent or at least a very very small one, then mathematically, it would be impossible because parts of the model would have to converge or diverge in some way.
It's fine to draw a schematic type elevation in 2D like this but it cannot work in true 3D
2007-03-22 02:23 PM
I'm sure there must be applications out there that can do this for manufacturing but i don't know what for sure. Perhaps CATIA? A machine has to know at some point what 'flat' shape a curved metal sheet actually is in order to cut it?TouchCAD is one such program: http://www.touchcad.com/tc3features.html
