2004-10-26
12:26 PM
2023-05-26
03:20 PM
Rubia Torres
2004-10-26 12:27 PM
2004-10-26 01:40 PM
2004-10-26 02:44 PM
2004-10-26 03:56 PM
2004-10-26 04:22 PM
2004-10-26 07:03 PM
2004-10-26 08:49 PM
patricprz wrote:I was thinking of 8.1. The preference is now set (in 9) in the Work Environment. See attached image.
Thank you for your reply!
I am a new user and I am amazed that within a week I have found a major flaw with the file management of Archicad files.
1. You told me to go to >Options>Preferences>Imaging and Calculation... but i do not have that option.... (see attached image, post below).
2. Does each project have its own library or does Archicad have one single "mother" of a library that feeds all projects?There are many ways to organize libraries. Essentially, all libraries are external to the project and so may be shared among many. The easiest way is to have one standard library that is used for all projects. This usually contains a folder for Out of the Box (GS & 3rd Party) libraries, another for office standards, and one for project specific libraries.
2004-10-27 12:56 AM
Matthew wrote:Another solution, oriented towards the CAD/IT manager and not the typical user, is a new GDL command (copying from the reference guide):
The Save as... Project Archive has a critical flaw. It doesn't include macros that are called by use of a variable name. In your case it is also failing to include the text file that the library part is referencing.
One solution is to select "Include all parts of loaded libraries" in the save as options. This can be problematic since the archive file will probably become quite large, and you will begin to create many multiple copies of the libraries.
FILE_DEPENDENCE "name1" [, "name2", ...]
2004-10-27 06:58 PM
patricprz wrote:Yep, nothing is perfect ... the way to achieve this is to rigorously write the GDL objects. This has been extensively discussed earlier.
patricprz wrote:As discussed, this depends on your Work environment; please check that. Plus, you ae probably in International version, while Mat and Karl are on US. That also differs.
patricprz wrote:Both
