Is there any reason why my AC18 bold marquee does not select all stories and the elements on them when asked to do so? I have an existing 3 storey building which is skewed onto my desktop (it was set out by a surveyor). I want to have at least one wall on the ground floor horizontal to my desktop to assist drafting. Obviously everything has to be adjusted at the same time and to the same degree. I've turned on all layers, set the renovation filter to 'show all', surround my entire building and notes e.t.c.. with a bold marquee and then 'select all'. Lines and objects appear marked as required. I select my chosen ground floor wall and rotate it to the horizontal. Easy!
But.....only the ground floor items have moved. Is this the expected behaviour in a 2014 CAD programme, or have I misunderstood AC's instructions and mucked something up?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
