2005-03-09
05:20 AM
2023-05-26
12:54 PM
Rubia Torres
2005-03-09 05:39 AM
MPatrick wrote:Hmmm.....nevermind......thats messed up, I have to update the priority level on every layer combination as well?
Have finally figured out the Layer Intersection Priority.....but why if I change a layer to "0" and I close (and save) the drawing it goes back to one again?
What I am trying to do is not have holes in my wall where a column is when I turn the column layer off....
Of course this same scenario is for a few other items as well, but the columns have been the most troublesome.
Oh....this is with 8.1 btw
2005-03-09 04:15 PM
2005-03-09 04:42 PM
Hmmm.....nevermind......thats messed up, I have to update the priority level on every layer combination as well? SadThat's so you actually can control when and where items intersect.
2005-03-09 05:21 PM
woodster wrote:Walls that are not used for actual walls, such as a shower door, or for the plywood in a roof system are a couple. I have also found that if I have a wall above a wall having a lower priority on that "hidden layer" does not cause conflicts with the walls below.
I'm trying to guess what it is that you are really trying to accomplish here? As structural elements, I would expect that there would be few instances in which you would want to hide them.
What other types of items?
Thanks,
woodster
2005-03-09 11:48 PM
2005-03-10 12:00 AM
woodster wrote:Knew about the shower door in the library.... using the custom shower door was for the architect I work with....I try to stick with the objects as much as I can...MPatrick wrote:woodster wrote:
While I always encourage users to "look beyond thenameof a tool" for other uses, one must also be aware of possible problems that might be caused by, for example, putting a wall on top of a wall. One must think of how they will interact with each other.
There's a shower door in Section 9 of the library (Shower D Corner); you can turn off the sides. It pays to learn what's in the library.
Use thin roofs for plywood on a roof system, for example; they won't interact with your walls unless you ask them to do so. Or create a composite that gives you the detail you need without all of the extra work of adding a skin of plywood over another roof.
Hope this helps.
woodster
2005-03-10 12:32 AM
MPatrick wrote:Use a slab.
As for the walls being used in a roof system, I am talking about vertical plywood. Kinda hard to use a roof at a 90 degree angle.....tried, it wont go that steep. So I only have a wall or beam that can trim to the plywood roof that I had already created. When I get to the office tonight I will post a pic so you can see what I am talking about.... problem about using a beam or wall is that it intersects with what is below.
