2020-07-11 02:51 PM - last edited on 2023-05-26 02:10 PM by Rubia Torres
Solved! Go to Solution.
2020-07-14 05:38 PM
LaszloNagy wrote:Dear Lastly
If you put the PLA file on Dropbox or something similar and send me the link in a private message, I may be able to look at it.
2020-07-14 05:49 PM
Barry wrote:Dear Barry
I had a look at the file and it seems to me you have something a very, very long distance from the origin.
Exactly what it is I haven't had time to explore and find out.
But if you place an all storey marquee around your plan and then view that in 3D you will see the model.
However if you remove the marquee and view all in 3D and zoom to extents, it will zoom so far out it does not respond.
There is something very far away on storey 0 and/or storey 1.
View those in plan and "fit to window" and you will see it zooms very far out.
Al the other storeys seem OK.
Sorry but that is all the time I have to investigate at the moment.
2020-07-15 02:50 AM
Have u got time to check the file? It would be really helpful if you can make some time
2020-07-15 05:55 AM
2020-07-15 06:02 AM
2020-07-15 08:25 AM
2020-07-15 08:56 AM
