2016-05-17 10:04 PM - last edited on 2023-05-24 08:40 AM by Rubia Torres
2016-05-17 10:43 PM
2016-05-18 12:39 AM
2016-05-18 12:45 AM
2016-05-18 01:10 AM
2016-05-18 03:53 AM
s2art wrote:Unless you turn off the 'Autohide special snap points' in the 'On screen options" of your Work Environment.
Then the race is on to move the window before the snap point disappears
2016-05-18 12:33 PM
Barry wrote:In ARCHICAD 19 and later this is now controlled by the Autohide Snap Points checkbox in the Input Constraints and Guides page of the Work Environment Dialog. With the new Guide Line and Snap Guide related improvements in AC19 this checkbox got renamed and moved to another page of the Dialog:s2art wrote:Unless you turn off the 'Autohide special snap points' in the 'On screen options" of your Work Environment.
It means the special snaps will stay on the screen until you (CTRL+ALT+SHIFT+R) or Archicad forces a rebuild and regenerate (i.e. when changing views) or you change the input method for the snap guides (off, between intersection, entire length).
2016-05-18 03:11 PM
2016-05-18 03:51 PM
s2art wrote:This has been my method for 10+ years, until I just learned about ALT + A from Laszlo up there
Or just hover over the wall before you start dragging the window. Then the race is on to move the window before the snap point disappears
2017-07-09 02:12 AM
arqrivas wrote:Hehe, that's perfect; thanks.
Hi, I know you are trying to get the center snap point, but here is a technique I use to center things in AC, I hope this can help you.
http://screencast-o-matic.com/watch/cDhFIiicKO
