Chain of Walls
Eman
Hi Guys and happy new year to all of you.
Please, why I cannot find the 'chain of walls' tool as the image?
https://yadi.sk/i/2umbtUfFHbMESg
Thanks in advance.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
David Maudlin
Eman:
Click and hold on the leftmost icon, a pop-up will appear with the Single, Chained, Rectangular and Rotated Rectangular options.
You should add your ArchiCAD version to your signature, these icons are different in the more current versions.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Eman:
Eman
Hi David and thanks for you help.
Eman / Draftsman
