Eman
Flat Roof
Hi guys,
I am really liking ArchiCad 😉
I have another little problem how to apply a flat roof? I can apply a slab easily but I cannot apply a flat roof with same method as the slab!
Thanks,
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
9 Replies 9
Eduardo Rolon
Flat roofs are done with slabs not with the roof tool.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Eman
Hi Ejrolon
Hmmmm OK thanks very much
Eman / Draftsman
Szabolcs Miko
That only means that you model them with the Slab tool. You can Classify them as Roofs though, in order to have it's property set.
Szabolcs Mikó
Manager, Customer Support
DGSketcher
Legend
Roofs can be drawn with positive or negative gradients which includes flat or 0 degrees.
Slabs are used where you do not need a slope e.g. floors
Tim Ball
Flat roofs are not flat in regions that have rain. So use the roof tool with a shallow pitch
Tim Ball
AC26, iMac
User since V5
Eduardo Rolon
But flat roofs are flat underneath so use the slab tool and if necessary use a mesh to get the rise as you need.
AC29 US/INT -> AC08
DGSketcher
Legend
Eman - As you can see from the posts above, Archicad is a very flexible tool and there are many different ways to do things. Learn what the tools do first and then when you get stuck, the members of this very helpful community will hopefully point you in the right direction.
Tim Ball
At working drawing stage I use a pitched roof for the covering and firrings zone, SEO cut by a slab below that is the actual roof structure and ceiling
Tim Ball
AC26, iMac
User since V5
Years ago I wrote an article about this for GRAPHISOFT. Here it is:
https://helpcenter.graphisoft.com/knowledgebase/25582/
