2011-10-0512:02 PM - last edited on 2023-05-2602:29 PM by Rubia Torres
2011-10-0512:02 PM
I have just upgraded to AC15 and am have issues when an element is partially selected by the marquee it changes colour/dulls down in the 3d window, is there some way to turn off this "feature".
Take a look at Work Environment > User Preference Schemes > Selection and Element Information > Highlight selected elements' surfaces, you can uncheck this or change the Surface color.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Upon further investigation, I found the real answer - goto 3D Cutting Planes, and check "Use Element Attributes" for the "Fill Material & Edge Pen of Cuts" Setting. Hope that helps!
ArchiCAD 25 & 24 USA Windows 10 x64 Since ArchiCAD 9
