Colour of elements partially selected in marquee AC15
Nuge
I have just upgraded to AC15 and am have issues when an element is partially selected by the marquee it changes colour/dulls down in the 3d window, is there some way to turn off this "feature".
Please help
AC27 i9 11900K / 128G ram / GTX 3090 / D5 Render
4 REPLIES 4
David Maudlin
Nuge:
Take a look at Work Environment > User Preference Schemes > Selection and Element Information > Highlight selected elements' surfaces, you can uncheck this or change the Surface color.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dennis Lee
Goto 3d window settings and turn on the TRANSPARENCY
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Dennis Lee
Upon further investigation, I found the real answer - goto 3D Cutting Planes, and check "Use Element Attributes" for the "Fill Material & Edge Pen of Cuts" Setting. Hope that helps!
Windows 10 x64
Since ArchiCAD 9
Nuge
Dennis,
you the man!! works a treat
thank you
