Column Display Problem on the floor plan
The Columns are placed on Story 6. The bottom height of the columns on Story 6 is -140mm. However I don't want these columns to be displayed on Story 5 with height of 4000mm.
I try to make the settings of the columns and the story 5 cutting plan as shown in picture 1 & picture 2. The column are still be displayed on Story 5 (shown on picture 3).
Any ideas for solving these problem? Thanks a lot.
Djordje
Check the column plan visibility settings in the Info box.
And BTW ... forget the dark background, you are losing a lot of the ArchiCAD ease of use and interactivity by using it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
