‎2025-06-24
09:28 PM
‎2025-07-16
11:58 AM
Molinda Prey
Hi there. I had some issue with Complex Profile Column and Wall Composite connection. I am doing this small gate casing outside the wall face. If the column profile has a sloped ending, the connection between the column and the wall on the floor plan is separated with the contour line. See photo:
But If the column has a horizontal ending, the connection between the column and the wall on the floor plan becomes seamless. See photo:
I want this seamless connection between the column and the wall but also want to keep the sloped ending of the column to finalize the outside casing.
Solved! Go to Solution.
‎2025-06-25 03:07 AM
Interesting problem.
The only fix I can see is to edit the edge of the complex profile and turn off that cut line.
That means that line will always be invisible when you use that profile.
‎2025-06-25 09:37 AM
Woah that looks like the best solution! Thank you!
