Complex profiled slanted and curved wall
Hi.
How can I create a wall with this shape (see image below) that has a wall height that evenly increases from start until end?
I have managed to do a simple case by simply creating a wall from polylines and convert it into a morph thereafter stretching the top end wall line downwards. This doesn't work though when the wall has a more complex polylines (more aggressive curves) e.g it has a lot of nodes hence it doesn't work to lower the whole wall after morphing it.
14 REPLIES 14
Create a curved wall with the wall tool,
Morph the wall,
Split it in two equal pieces,
Use the pet palette to offset edges up or down to suit.
That's what I have tried but I can only create the desired shape by magic wand. The thickness of the wall is also inhomogenous and one end of the wall is not a straight line, it is pointy. Hence I cannot even pull down that line with offset.
Eduardo Rolon
Basic tutorial.
1. Start with the fill in floor plan of the wall shape
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Using the Polygonal Wall Method, magic wand the fill to get the wall
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Result
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Using a Roof, Shell or a Mesh define the top edge of the wall
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Using Connect SEOs subtract with upwards the Mesh/Roof.
In this case since I used a roof I used Connect "trim elements to roof/shell"
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Place the Roof/Mesh/Morph/Shell on a specific layer ( I use x-SEOs) and hide the Layer.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Example of using a Morph to define the Top Edge of the wall since you can move the points in Z. You can magic wand the Morph to the original fill.
AC29 US/INT -> AC08
another Moderator
