Bruce
Composite Junction
Any ideas how to get this displaying correctly?
Thanks in advance
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
15 Replies 15
Rod Jurich
Matthew wrote:
That's how I've done it for years. Either face of stud or face of finish depending on the practice.
It's gratifying to know I'm not alone. When I brought this up with a number of other locals all I got was odd looks, although 2 offices I've had some influence, see the obvious benefit.
By the way Matthew, how is/was "sunny" England?
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
PatriciaLe_o
Sorry to ask something that might be too basic for you, but it's still in this subject... How can I edit a slab ending, made with a composite material? I wanted a command like the "wall end" but used on slabs...
Patricia Leão
AC21 INT Full
MacOSHighSierra
__archiben
you could try the slab accessory - if you're using AC10 go to your help menu and choose 'ArchiCAD 10 Goodies - download the 'accessories' add-on and 'accessories library'. in AC9 it's built in as a part of the installation.
additionally - if you want a more extensive slab edge treatment - try the cadimage accessory tools 'Foundation Builder' (shown below) . . .
HTH
~/archiben
b e n _ f r o s t
PatriciaLe_o
Thank you Ben! I'll just download it right away!!!!!
Patricia Leão
AC21 INT Full
MacOSHighSierra
PatriciaLe_o
Me again... I downloaded the goodie but it didn't seem to be helpful... How should I build, if I want the joints to look like this? Should I put one slab over the other!? And how about the exterior walls joining the slab? How can I make the insulation "cross" the slab?
Sorry if I was confusing....
Patricia Leão
AC21 INT Full
MacOSHighSierra
PatriciaLe_o
this should have been the first image...
Patricia Leão
AC21 INT Full
MacOSHighSierra
