2026-02-18 09:12 PM - last edited on 2026-02-19 01:47 AM by Barry Kelly
Hi, im trying to make a fasade that consists of 2 izolation materials that are different in thickness, the wall on top is just a composite wall made from brick and isolation, the lower one is a "profile". The profile wall is causing composite wall to extend or make holes. Thanks for any help
Language of Archicad 29 - CZ
Solved! Go to Solution.
2026-02-19 02:29 AM - edited 2026-02-19 02:34 AM
Change the Reference Line position of one of your walls. This generally occurs when multiple walls have their Reference Lines overlap. Alternatively, you could do your footing as a beam.
Ling.
ps. If the walls overlap vertically, even between storeys, avoid having their Reference Lines overlap in plan.
Ling.
