Copy & paste excel
i've been trying to copy and paste excel (general notes) onto plotmaker.
i read the archiguide online for linked objects and i'm still not getting it.
attached is a screen print of the results. i have turned off the grid and change the view from page break ( blue solid and broken lines don't show) to normal in excel before copy and paste.
but i still see the blue solid lines.
please help.
ac7r3/xphome
3 Replies 3
Djordje
Did you save the file before copying?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djorde..
what i discovered is to make sure the View is in Normal. But I am stillfiguring out how to have a 'good' width text without having it 'wrapped' when pasted on excel. any good rule?
Djordje
I usually double click the columns to fit to text width, and keep one column and row "frame" around the area I need ampty, at the row height. I then copy all including the "frame". I usually paste into PlotMaker, don't remember when I pasted into ArchiCAD, as Linked object.
Mind you, these are normally tables. Yes, view should be in Normal.
Djordje
HP Omen
