Cover Fill Orientation in RCP
Red
I feel there isn't a way to do this, but I thought I would ask to see if I am missing anything. I have a composite slab created for my ceiling. Once the Custom Fill Orientation is set to Link to Fill Origin and adjust the angle of the Cover Fill, everything is great in the normal floor plan view when drawing in the slabs for the RCP; however, I assume there is no way to adjust the bottom of a composite slab Cover Fill angle for the Reflected Ceiling Plan when using a 3D Document? I have typically created extra Surface(s) for each angle needed rather than drawing in each ceiling layer as separate slabs...
Operating system used: Windows 3001
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
JeffH
in 3d with the ceiling slab selected, you should be able to go to Document/Creative Imaging/Align 3D Texture/Set Origin.
Pick the point, and the fill should adjust accordingly
AC24 / AC26 / AC27
Win10
JeffH
AC24 / AC26 / AC27
Win10
Thank you. I obviously did not think about the align texture feature and it also rotating the cover fill, but it makes sense that it does.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Setup info provided by author
