Roopa A
Create Lion and Cow face
Hai,
I need to create face of lion and cow, I tried with morph, I am not getting it properly as I want.
I searched for object also, I dint get it.
Please any one help me in this.
I have attached the image how it is to be . The sectional view of that.
Thank you.
Roopa A
Roopa A S
37 Replies 37
Roopa A
Yes, Its working.
Thank you so much.
Roopa A S
Roopa A
I got the object from cadnav.com website.
Here is the link of that object.
http://www.cadnav.com/3d-models/model-47942.html
I need to import this how to import??
It is in .max, .dds format.
Thank you,
Roopa A
Roopa A S
runxel
If you don't have 3ds Max you're out of luck. Nothing else can open this format. Even every file converter I know needs to have 3ds Max installed on your PC.
Roopa A
Can anyone convert this file and send it.
If possible??
Thank you,
Roopa A S
Roopa A
I need to create a saree for goddess. I have created the model. Here is the image and model attached.
How to show the saree design for this?
Please help me.
I got the objects from sketchup, but it not proper.
So.
Thank you,
Roopa A
Roopa A S
Nader Belal
Mentor
You will need a 3D modeler or digital sculpture, that if you didn't find a suitable model for your project.
Another way to do it, but it may be a long shot ....
Go to Youtube and search for how to create 3D models from images using Photogrammetry (wikipedia: https://en.wikipedia.org/wiki/Photogrammetry#:~:text=Photogrammetry%20is%20the%20science%20and,radiant%20imagery%20and%20other%20phenomena.)
The benefit, you can choose the model that you want & you see fit for your project from already available statues, using only your mobile, 100s or even thousands of photos, your computer, and it would be free.
And may be size wouldn't matter, but the bigger the statue you may find, the better quality you may achieve.
The cons:
1-The photos must be of good quality.
2-You should use a good photogrammetry program.
3-Available resources on your PC vs needed resources.
4-Time
A good friend of mine have once told me that I´m so brute that I´m capable of creating a GDL script capable of creating GDLs.
Roopa A
I have created the saree as shown in the image.
Need to fine tune , Help me in this.
Here is the image attached.
Roopa A S
Steve Jepson
TurboSquid - Of couse!   I have actualluy bought a cows for less money than you can buy some of these TurboSwuid Cows.  I rember when you could buy a pretty good milk cow for about $800.00      Dairy cow 3D model - TurboSquid 1443704
