Create a fence-structure using cuirtain wall?
Kamelite
Is it possible to use Curtain Wall to create something similar to this?
.Kamelite
Operating system used: Windows 10
Windows 10, Archicad 28
Lingwisyer
Guru
Sure? I would do the mesh as a texture on a panel though.
CosminF
Yes.
You could use the curtain wall for the metallic frame and the for the panel just use a texture with proper alpha channel so it is see-through. And it will allow for design flexibility, door placement etc.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Setup info provided by author
