2017-07-10
09:57 AM
2023-05-24
08:29 AM
Rubia Torres
2017-07-11 12:04 PM
2017-07-11 12:08 PM
2017-07-11 05:44 PM
2017-07-11 05:54 PM
2017-07-11 06:12 PM
Will the merge option not function if the walls are parallel but slightly different lengths?Not necessarily. You can have walls at different lengths and they will merge. Maybe there are some special cases where it wouldn't work. It would require some trial and error.
Is there a way to unmerge walls and/or change the build up for the two separate elements once they have been merged?There is not an "Unmerge walls" command, but you can edit the complex profile after it has been created and save variations.
I.e. I want to change the build up of the wall below the cladding or the depth of the claddiing above after I have merged the two walls?
2017-07-11 06:28 PM
2017-07-11 06:35 PM
2017-07-12 10:36 AM
2017-07-15 03:36 PM
thompsonmp wrote:I will forward this wish to GRAPHISOFT for their consideration.
On a different note, one feature of the Autodesk site that I liked was the ability to mark a response on the forum as the answer/solution to a question/problem. Is there any chance of adding this function to Archicad-talk (I'm not sure who would be able to answer/implement this)?
